Can’t make out 502 mpi timing marks. >
Can?t make out 502 mpi timing marks.
Old 06-18-2022 | 07:47 PM
Default Can’t make out 502 mpi timing marks.
Anyone have a picture of a new balancer so I can see what the marks are. I can’t make these out.
cloudmaster_321 is offline
Old 06-18-2022 | 07:54 PM
SB
Look for timing tab basically off of timing cover.
SB is offline
Old 06-18-2022 | 07:57 PM
I only have a pointer
Old 06-19-2022 | 04:06 AM
Veteran: Army
I think the little white mark, and the scratched off paint, represents 8 degrees. I think I can see a zero at the next mark past it, indicating 10. I added some markings to your pic to show you what I think I'm seeing.
DrFeelgood is offline
Old 06-19-2022 | 02:01 PM
ok, if that’s the case, I’m right about 8-9 degrees then
Old 06-19-2022 | 03:25 PM
SB
Could also use an adjustable timing gun or measure diameter snd do math
SB is offline
Old 06-20-2022 | 07:13 AM
that deep groove is tdc use an advancing timing light
boostbros is offline
Old 06-20-2022 | 12:38 PM
And the line scribed in closer to the bottom, that is not as deep, is done at merc for timing at full advance. It would mark 32* in most cases.
Griff is offline
Old 06-20-2022 | 12:52 PM
Veteran: Army
nevermind
Old 06-26-2022 | 03:41 AM
hy...can i ask you what is the distance from your tdc on your pully to your 10 degree...i yust want to check..my is 0.6 inc..tnx
Zole is offline
