Upholstery removal tips/tricks on 252 Islander? >
Old 06-20-2022 | 08:10 PM
Default Upholstery removal tips/tricks on 252 Islander?
I've noticed that on my bow seating, port side, the seat back seems to be pulling away from the frame, I have exposed staples I can see when I look straight down on it. I am trying to figure out how that piece comes off...is it the 'Christmas Tree' style clips like used in automotive, but larger? I've felt around in the mid cabin on the upholstery in it and cannot feel any sort of bolt/screw/fastener underneath it that would allow it to come off that way.
Any ideas?
Baja 252 Islander
bajaman is offline
Old 06-29-2022 | 03:49 AM
Bolted from the back or the piece on the right needs to come out first.
carnutsx2 is offline
Old 06-29-2022 | 07:27 AM
Active Streak: 30 Days
From my experience on the few pieces I have removed on a couple boats, you need really LONG Arms and fingers!
Helmwurst is offline
Old 06-29-2022 | 11:48 AM
Any ideas?
How about removing the port side glovebox or radio to gain to the area behind the seat. My experience with Baja interiors is that they’re bolted in from behind with 5/16” bolts into speednuts pressed into the wood seat backer.
Baja_260 is offline
Old 06-29-2022 | 05:16 PM
There's a small mid-cabin that gets me access right behind the seat, and I have tried in vain to find anything that bolts to the seat back. It IS very thickly padded upholstery in there but still, you'd think I could feel something underneath it? And I don't. The left side of that top piece that sweeps around towards the front of the boat definitely has the 'Christmas tree' type of fastener as I can see it; it's actually a bit loose and I can pull the seat back away from the hull some. But I don't see anything similar on the back of the seat that faces forward.
Baja 252 Islander
bajaman is offline
Old 06-30-2022 | 06:21 AM
It may be worth a call to XT-Innovations in Ohio. They were involved in the design and manufacturing of the Baja interiors from that generation. I had called them years back when I had my old 260 and they were very helpful and knowledgeable. They even still had most of the factory patterns for the seats back them, I’m sure they still do. They’d be familiar with how those bolsters attach to the deck.
Baja_260 is offline
Old 06-30-2022 | 12:36 PM
^Sounds like a Plan! Thanks.
Baja 252 Islander
bajaman is offline
Old 06-30-2022 | 08:18 PM
Sure thing, good luck. Let us know what you come up with.
Baja_260 is offline
