Holley 4150 (9381) 830 Jetting >
Old 06-21-2022 | 11:05 AM
Question Holley 4150 (9381) 830 Jetting
I know this is a sacrilege but I am going to detune the 500HP clone in my 22 Classic Donzi to make her more manageable around the marina.
502, 9.5/1, Dart heads, Gil exhaust (Long risers), Crane HP500 cam retarded to 111* ATDC
Currently running a HP500 World Products single plane high rise.
Going to a GM dual plane aluminum high rise.
Currently running 78s and 6.5 power valve in Primaries, 91s w/plugged power valve in Secondaries.
Sea level
Does this jetting sound about right for the dual plane?
THANKS!
RickR is offline
Old 06-21-2022 | 12:01 PM
articfriends's Avatar
Sea level
THANKS!
Watch how #3 colors with that intake as its about the leanest cylinder, 2 will be rich, no way around it, ignore 2 if doing plug readings, Smitty
articfriends is offline
Old 06-21-2022 | 12:28 PM
SB
What sre you having problems ‘around the dock’ with, specifically ? Maybe just a carb or ignition issue ? I know the non marine 830’s can be pain in azz to tune for some reason. Marine 800’s like that came on hp500’s are straightforward. Once those are fixed/tuned correctly Can even mellow idle out more between shifts with a Daytona Sensors box probably.
SB is offline
Old 06-21-2022 | 02:54 PM
Are you interested in parting witj the singleplane intake? If so, how much?
jeffer is offline
Old 06-21-2022 | 08:14 PM
Best me to it.
Smitty275 is offline
Old 06-21-2022 | 09:44 PM
i assume your talking gms copy of a edelbrock performer rpm intake, if so, thats a GREAT intake for a 502, you'll see a 20 to 40 or MORE foot lb of tq increase in usable powerband at the sacrifice of 5 to 8 hp from 5500 to 6000 that most boaters never even reach. I discourage my customers from ever single planes on 502s and smaller unless they want to pump compression to octane limit, put a huge cam in that also sacrifices tq and spin it 6k, Smitty
Old 06-22-2022 | 07:32 AM
THANKS I will check #2
RickR is offline
Old 06-22-2022 | 07:45 AM
Idle too high or she loads up. I will look into Daytona Sensors
Originally Posted by Smitty275
Best me to it.
Plan on keeping it.
Yes, similar intake. 5800 RPM motor but usually prop for 5600. PLENTY of torque for a 3800# boat. I don't mind a little off the top end if it will keep people from shaking their fist at me in the marina
THANKS, for the help guys!
RickR is offline
Old 06-22-2022 | 10:32 AM
Plan on keeping it.
I've dynoed 502s with both, a perf rpm makes significantly more power thru 60 of power band, about same power for next 20% and gives up 2%hp on top unless your talking 10, 10.5-1and a cam in the mid 240s or bigger for most part.. we made 640 hp and 625,630 tq are (open headers, no accessories) w perf rpm, afr 305s, Bob m cam , 850 holley and 2" of carb spacer. 26 ft liberator it went in has broke 80mph mark gps with good air and low fuel fwiw.
