2 Rebuilt Mercury Racing ITS Transom Assemblies >
Old 06-30-2022 | 09:01 PM
Default 2 Rebuilt Mercury Racing ITS Transom Assemblies
2 fresh ITS Transom Assemblies
One rebuilt by Collabella Performance, other rebuilt by Gulf X marine, designer and builder of B-Max Drives.
Both are ready to bolt on and go. These have the built in 7 inch setback, built in hydraulic steering and Bravo gimbal. Completely rebuilt including steering rams, seals and bearings!
$4500 each
calls only, 239-443-8233
777offshore is offline
Old 07-11-2022 | 07:34 AM
Do you have any pictures of the parts being sold with the ITS setup? Does it come with the extended driveshaft? Thanks!
the dan is offline
Old 07-21-2022 | 03:27 PM
Drive shafts are sold separately because mercury has 2 different size U joints and you need to order the correct one to fit your drive.
Old 07-23-2022 | 01:56 PM
If your boat is already setup for standard transom assemblies, what is the likely outcome of having drives lower in the water due to the 7" setback? Would you end up being slower?
blown is offline
Old 07-23-2022 | 08:47 PM
The ITS's have a built in 1.5" lift to the boxes. This should in general keep the props depth the same as standard transom assemblies but gain the advantage of the better leverage of the drives being further off the transom.
Old 09-14-2022 | 02:33 PM
I am interested in theses. Please call me back. I left you a message. Thanks.
Patfeldnky1 is offline
Old 10-02-2022 | 06:34 PM
Are these still available?
papatj is offline
Old 10-03-2022 | 12:08 PM
There good for brave or bmax only ?
Any pics ?
Bulitz1 is offline
Old 10-03-2022 | 12:13 PM
F-2 Speedy's Avatar
the OP states calls only, he hasn't been on here since the end of July.......seeing he's FL he might be dealing with bigger issues
F-2 Speedy is offline
