Oil leak under power >
Old 07-05-2022 | 09:06 AM
wieland77's Avatar
Default Oil leak under power
Having an issue with my Bravo XR leaking oil and also getting some water in the oil of my drive only when its under power. I had it pressure and vacuum tested and holds pressure fine. After running it yesterday I can see some oil residue on both sides of the upper where the drive bolts to the bell housing. Assuming it has to be one of the o-rings not sealing around the shift cable to reserviour line but wouldn't that make the pressure test fail?
wieland77 is offline
