Old boat owner, new baja owner have throttle questions >
Old 07-16-2022 | 02:39 AM
Default Old boat owner, new baja owner have throttle questions
Hello,
I just picked up a 1988 Sunsport 196. I've noticed that the throttle lever does NOT have the neutral center button. Was this normal back then?
Cold natured boat and could use that switch.
Outside of lifting the rear deck and thumbing the carb, any thoughts on a permanent fix? Possible to upgrade this throttle?
I'm sure I'm gonna have more baja questions, but start with this simple one
Jerry39047 is offline
Old 07-16-2022 | 05:16 AM
SB
Not sure which control you have, but if a side control without a button, the throttle lever when straight up (neutral position) can be moved to left , we which disconnects it from the forward/reverse mechanism, letting you open throttles as you wish in neutral.
SB is online now
Old 07-18-2022 | 07:23 PM
It doesn't move. Has a screw behind the center area cover.
Also, has a 350 stern drive alpha1 gen1. Any idea what props came on these? 14x21?
15x21?
Old 07-19-2022 | 01:11 PM
Disregard the screw. Try to grasp it at the red circle area firmly and pull out. Wiggle fore and aft maybe at he same time.
Post a picture of your control also. That'd be a great help to you.
cheech is offline
Old 07-19-2022 | 08:32 PM
Won't let me post a pic, but I did get the lever to pull out finally.
thanks for the help
