1987 242ls >
1987 242ls
1987 242ls
Old 07-30-2022 | 07:15 PM
Default 1987 242ls
Well, we have been enjoying our 1987 242LS on Cayuga Lake here in NY for the past couple of weeks. It took our vendor a lot longer than expected to get the interior re-done but boy does it look good. They did new wood, foam and vinyl on the seats, sun pad and interior. Interesting to note that they did not measure the sunpad correctly and were two inches short with the vinyl/foam. However, this mistake worked in our favor as our hatch needed to be put together correctly and we needed to install a hatch lift. Our mechanic partnered with a welder and you can see the two inch strip of metal they added in the pics. It looks great and operates perfectly. There was no need to drill into any wood or vinyl.
Old interior was full of mildew and mold and waterlogged.
This metal strip is new and covers the two inch gap left by our upholsterers.
Here is the stronger support underneath the hatch.
Stickboy is offline
Old 07-30-2022 | 09:06 PM
Looks very nice and you won’t go wrong with the beefier hinge back there. Sometimes those “mistakes” end up working out quite nicely, like in your case.
Noles1 is offline
Old 07-31-2022 | 03:18 AM
looks great you be happy with white its cooler in the sun
j272 is offline
Old 10-18-2022 | 05:12 AM
Registered User
Turned out beautiful!
myoung3538 is offline
Old 10-19-2022 | 03:29 PM
TomZ's Avatar
I might need to duplicate that! The original setup is pretty flimsy... my 311's flexes a lot.
TomZ is offline
Old 05-03-2023 | 03:28 AM
Looks like only some of these came with tow hooks on the transom. Do you know if the ones that do have tow hooks are all aftermarket installs?
NorCalNomad is offline
Old 06-25-2023 | 08:29 PM
OP
do u have the storage bins for the engine compartment?
88242LS is offline
Old 07-05-2023 | 06:08 AM
Default Storage Bins
Nope we do not have storage bins in our engine compartment. Do you have a picture you could share?
Stickboy is offline
Old 07-05-2023 | 06:10 AM
Default Tow Hooks
Unfortunately I don't know if the tow hooks on the transom are from the factory or not.
Stickboy is offline
Old 07-05-2023 | 05:51 PM
you can kinda see them.in this guy's ad,
https://www.facebook.com/marketplace...ibextid=dXMIcH
88242LS is offline
