Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
1990 fountain fever stringer repair >
Old 08-01-2022 | 09:52 PM
Default 1990 fountain fever stringer repair
Front of my bow needs wood and glasswork could use some tips from you guys.
Going to glass it in sections
front of my bow needs wood and glasswork could use some tips from you guys.
BigSobe is offline
Old 08-02-2022 | 01:02 AM
Lots of old threads in this section with pics and pointers.
Another recent thread here Cigarette Topgun
Griff is offline
Old 08-02-2022 | 07:46 AM
Active Streak: 30 Days
Looks like it has been stored bow down. You can see the water line along the hull. How does it look in the stern? What about under the cockpit?
Helmwurst is offline
Old 08-02-2022 | 11:01 AM
About the same boat was stored on a lift drain plug out but got some debree got in the drain plug and it was drained but not sure how long the water sat owner claimed not long.Boat was stored on lift bow upwards Tho.
BigSobe is offline
Old 08-02-2022 | 02:32 PM
I've done a bunch of transoms, but nothing in the cabin. Most I've seen that have a major cabin redo pull the deck.
CDShack is offline
Old 08-04-2022 | 11:10 AM
What resin should i use some say poly some say vinyl depending on application is glass dave around I here hes the man
BigSobe is offline
Old 08-04-2022 | 12:01 PM
Price of vinyl has increased so high it’s not worth the savings over epoxy.
Unlimited jd is offline
Old 08-06-2022 | 11:43 AM
Is there any issues with using epoxy stiff wise on the stringers
BigSobe is offline
Old 08-15-2022 | 10:02 PM
glassdave's Avatar
Neno the mind boggler
give ya a shout tomorrow Sobe, just saw the PM
08 OPA High Points Champion
glassdave is offline
Old 08-18-2022 | 11:55 AM
ok
BigSobe is offline
