Drive tilt trim hose >
Old 08-07-2022 | 03:57 PM
35fountain's Avatar
Default Drive tilt trim hose
I had a trim hose start leaking. It's is made by Parker.. Runs from the pump in the engine compartment back of seat to a connector near the transom. Starboard side. Its about 92" long 3/16 one 90 degree end fitting and one straight fitting.
Parker C25m3 Any ideas where i can get a replacement. Thanks in advance
35fountain is offline
Old 08-07-2022 | 06:12 PM
Veteran: Army
Any hydraulic shop should be able to make up a duplicate for you.
DrFeelgood is offline
Old 08-08-2022 | 01:38 AM
The Quicksilver hoses are black and grey:
The black is part number 32-861127.
But based on the length of your hose, I think the Quicksilver hoses are shorter.
If you want me to measure one, then please let me know?
Phazar454Mag is offline
Old 08-08-2022 | 03:32 AM
Veteran: Army
Right, I have a few of those but they seemed too short for the OP's application so I didn't mention it.
Old 08-08-2022 | 05:27 AM
Yes, I have just measured, and the hose part (without fittings) is app 110 cm, which is 43", so they are way too short.
