Starter dont start !!!!
Guys !
i need your help!
im good at many things but f#%k all in electricity.. so i was running and stopped my 500 efi... one would not start back. Like nothing, completely dead. No click , nothing...
so i had a spare ignition, tested the new, did not work, so i put the original back
then changed kill switch, nothing again
so i put original back
came back home limping
next morning i try to start and it works !
so i changed the solenoid on the back top of engine. Today i went boating and started fine
then i shut the engines off, and same would not start again since it was warm again...i put my gator clip jump starter on the changed solenoid, and starts fine no problem
so where should i look next? Solenoid direct on starter?
i need your help!
Yes. Key switch may be OK, but wiring/connections between the key switch and solenoid may be compromised leading to an excessive voltage drop. Issue could be before the key switch. Start taking voltage measurements at starter solenoid and if low, start working your way "upstream" until you find where the excessive voltage drop occurs. The neutral safety switch wires being "twisted together" may be causing a voltage drop too. All elec connections should be crimped or soldered.
Also good to check eng grounding.
Drawing out the start circuit may help troubleshoot. Do you have 2 solenoids for each eng? One on top of eng and one on starter??
