Funny question - water shooting out of exhaust a minute or two after shutdown >
Old 08-23-2022 | 05:19 PM
TomZ's Avatar
Default Funny question - water shooting out of exhaust a minute or two after shutdown
Port engine. After shutting down for flushing after being out, the odd bank puked some water under pressure. I've heard it do it before, but not consistently. This last time I caught a glimpse of it when climbing down the off the boat.
If anyone remembers from back in late 2020, I had signs of water intrusion on both 7 and 8 as well as some exhaust valve issues. The old heads (088s) ended up being junk from rust in the exhaust ports as well as intake face issues.
Headers - they're CMI etops - old - but they lived in brackish water for years and then only got into salt down here with two and a half seasons. They have been extensively pressure checked with a propane torch and water tank. They held over 40 lbs with the pressure increasing while heat was applied to the ports and collectors. I think they're good.
Anyone see anything like this?
TomZ is offline
Old 08-23-2022 | 05:42 PM
TomZ's Avatar
Actually, I think the first time I noticed this happening was after I removed the silent thunder and went to the aluminum with open exhaust. That was in 2018.
TomZ is offline
Old 08-24-2022 | 01:29 AM
So, what’s the problem??
Griff is offline
Old 08-24-2022 | 07:43 AM
TomZ's Avatar
It seems like a pressure builds up and then shoots water out of that side.
Probably concerned for nothing?
TomZ is offline
Old 08-25-2022 | 11:55 AM
TomZ's Avatar
No one has seen this before?
TomZ is offline
Old 08-25-2022 | 12:01 PM
F-2 Speedy's Avatar
never seen or heard of this, when the pump stops spinning there shouldn't be any pressure
F-2 Speedy is offline
Old 08-25-2022 | 12:14 PM
SB
Bilge pump thru hull ?
SB is online now
Old 08-25-2022 | 12:15 PM
TomZ's Avatar
Correct. When it shuts down, the pump drops pressure and no water should flow. This is sounds like there's a pressure release and then a splash. My buddy said it was a quart but I'm thinking more like half of that.
Maybe there's a blockage in the header somewhere that traps water, heats builds up and blows it out. I'll look at it more this weekend.
TomZ is offline
Old 08-25-2022 | 12:19 PM
TomZ's Avatar
I wish. But they’re on the side. It is similar to that. Just a spit like the bilge pump came on for a second.
TomZ is offline
Old 08-25-2022 | 12:20 PM
Wally's Avatar
Were doomed!
Is it possible you have some debris in the exhaust passages near the bottom of the pipes and its blocking some (but not all) of the water draining out of the exhaust....then when you shut down the hot engine boils a little bit of the liquid and burps it out? just thinking out loud..
-Wally
Wally is offline
