volvo penta 8.2 pushing dpxr drives  overheat >
Old 09-02-2022 | 06:02 PM
Default volvo penta 8.2 pushing dpxr drives overheat
I have a 31 sunseeker hawk with 1994 volvo penta 502s pushing DPXR drives. overheats over 3500 rpms fresh water cooled, new water pumps, heat exchangers, manifolds and risers. need help? should I run direct strainers? thru hull and forget the drive pick ups? that's all I can come up with? any help greatly appreciated! 🙏🙏
sunseeker31 is offline
Old 09-02-2022 | 06:55 PM
Veteran: Army
Both engines doing the same thing?
Did they both start doing this at the same time?
DrFeelgood is offline
Old 09-02-2022 | 08:50 PM
Default overheating
I just bought the boat and it needed 2 transom assembly which I found brand new. pulled the engines and put everything back together. and ran the boat. anything over 3500 runs up temp. yes they both do same thing. very sad.
Old 09-03-2022 | 03:59 AM
Veteran: Army
So you don't know if this problem was present before you did all that work?
Old 09-03-2022 | 06:34 AM
Default overheat
I called the owner that I bought the boat from and he said he never had it overheat problem but then he also said he never took the boat over 3000 rpymes.
Old 09-03-2022 | 07:12 AM
Funny
Connect a piece of short piece or clear hose between raw water pump and heat exchanger. Look for bubbles when running
Use a IR Temp gun to measure Temp at thermostat housing to verify the actual Temp
AllDodge is offline
Old 09-03-2022 | 08:17 AM
Default overheat
I will do that. thank you. what should that temp be?
