350 Mag MPI "cool fuel" housing >
Old 09-18-2022 | 11:54 PM
mcollinstn's Avatar
Default 350 Mag MPI "cool fuel" housing
I have seen these called "cool fuel" units, as well as "fuel module" units. Merc calls them a fuel module. It has the pump, the filter, and the fuel is water-jacketed to cool it (hence the cracked housing from freezing mentioned below).
I need either a complete (working/non-working/whatever) Merc "cool fuel" unit that DOESNT have a cracked housing. Neighbor did not properly winterize and his now has a crack that leaks water. I only NEED the housing, buy I'll be glad to take one with a bad fuel pump or other troubles and scavenge the housing from it.
PM me or email me direct
[email protected]
HINT: Once he brings me his unit and it's in my hands I plan to charge him $150 to disassemble it, clean it, vee out the crack, drill the ends of the crack, preheat it, weld it, pressure test it. So there's really no reason to pay more than that for another housing (unless I can't get it to pass the pressure test).
mcollinstn is offline
Old 09-19-2022 | 08:52 AM
TomFTM's Avatar
I have one cool fuel setup off a 305 tbi . I will look it up. And see if it is the same as what ur looking for.
TomFTM is offline
Old 09-19-2022 | 09:19 AM
SB
If you can’t find a good used unit for cheaper, if you have this style you can get the housing by itself:
https://leadersrpmshop.com/mercury-m...odl-8m0047216/
SB is offline
Old 09-19-2022 | 09:23 AM
F-2 Speedy's Avatar
great price SB saving 117 bucks..........
F-2 Speedy is offline
Old 09-19-2022 | 09:47 AM
SB
#1: Everyone else seems to be around $580 for this piece.
#2: Whole unit is around $1600 and change
I did my ‘job.’ lol
SB is offline
Old 09-19-2022 | 10:06 AM
TomFTM's Avatar
looks like it might be the same , the one I have fits a few 350mpi’s. Here is a pic.
$250 plus ride.
TomFTM is offline
Old 09-19-2022 | 10:41 AM
mcollinstn's Avatar
this is the style I need.350 Mag MPI "cool fuel" housing-8m0047216_1__79860.jpg
Old 09-19-2022 | 11:06 AM
SB
Originally Posted by mcollinstn
this is the style I need.Attachment 577399
Link didn’t work.
it’s same part# I linked above.
Here is pic:
SB is offline
