torque roll
Back in the early eighties I briefly ran around with a guy who had just taken delivery of the 1st factory Big block Donzi 18 , 370 horse thru a Trs.
You could lay that thing right up on the rub rail from 20 to 40 mph if you mashed the throttle hard enough, same with getting out of it too fast.
I had a over powered 272 baja, ran a best of 99.5 gps, in my quest for speed I treid various props. At one point I tried a 5 blade maximus prop and boat would roll onto nits side everytime you leaned on throttle, It was 100% undrivable, I feel its prop more than anything, was fine with a 4 bladelabbed, did it a little with a std prop. My friend had one of those narrow 24 foot sunsations, he could only run 3 blades or boat tq rolled rel evil fwiw, Smitty
I have found that a touch of trim tab on the "downhill side" works to settle torque roll and chine walk when I'm leaning on the throttle.
Thanks. Brad.
(937)545-8991
LTZCrew,
Assuming you're asking me....
My tabs are all but level with the bottom of the boat, only slightly elevated, while cruising. When I lean into the throttle, I don't think the tabs are really doing much, and it starts to chine walk above about 72-73MPH. I will tap a couple times on the left tab "bow down" button, just enough for the next indicator light to come on, and the chine walk goes away and the boat runs level, assuming passenger load is pretty evenly distributed. If I don't lift the left tab after coming back down to cruising speed, I notice the boat will lean to the right a bit until I do.
I am running a PQ 280, 496HO, M1 ProCharger, through a stock Bravo1 drive with a stock Bravo28 4B.
Thanks. Brad.
(937)545-8991
Thanks. Brad.
(937)545-8991
