Fel Pro Gaskets needed.
BBC Gen VI Gaskets _need help finding right FelPro gaskets for 502 GenVI motor. Tired of looking through all the websites that redirect me all over the place.
Need Oil pan gasket
Timing Cover gasket
Timing Cover seal
Thanks in advance
Need Oil pan gasket
Timing Cover gasket
Timing Cover seal
Thanks in advance
as far as I know the 502 is no different than a 454 on the measurements so you should be able to look up a 1996-98 chevy one ton with a 454 and the gaskets should be the same. only gasket that should be different is head gasket due to the bore size.
