1990 mirage intimidator 270 >
Old 10-12-2022 | 07:04 PM
Default 1990 mirage intimidator 270 with fixing?
I have 1990 mirage intimidator 270 with twin 454 gen 4 330hp engines. I bought this boat as a project...The engine are both bad and really looking for advice. I plan to use it at lake of the ozarks missouri. I have a shop that can put a gen 6 cam in making it a roller cam vs flat tappet. full rebuilds are gonna be at 20k for the pair. has bravo 1 drives that need new bellows. Would i be better of scrapping the project our putting the 22k into it between engines and bellows? Tia
id post photos but because im a new member and do not have 10 post i cant post photos
zasmith is offline
Old 10-12-2022 | 08:11 PM
SB
Post whore 9 more times.
20k seems like aweful lot. They pulling engines ? Replacing exhaust ?
Have boat surveyed for soft spots… transom and stringers ?
SB is online now
Old 10-12-2022 | 08:17 PM
I pulled engines myself. That basically a long block with ls6 heads, roller cam gen 6. He said be rite at 450hp and engine.
zasmith is offline
Old 10-12-2022 | 09:05 PM
zasmith is offline
Old 10-12-2022 | 09:08 PM
Only interior pic i have orange and purple but it is frshly done 2 years ago
Looks good from far. Not perfect but hell its 32 years old
zasmith is offline
Old 10-12-2022 | 09:09 PM
Just wonder if I have a money pit. Or worth redoing. I'm in missouri never had a boat surveyed. Don't even know what that really is
zasmith is offline
Old 10-12-2022 | 10:08 PM
Money pit for sure, but most boats are.
If you got the boat for free, you will still have more $$ invested in it than it will ever be worth and thats even if you do all the labor yourself.
The hull has little value and the boat will be worth the value of the major parts
Griff is offline
Old 10-13-2022 | 10:17 AM
Check for rot. My '87 Mirage had rot. I had to replace the stringers and floor. Did it all myself but it was a pain.
87MirageIntruder is offline
Old 10-13-2022 | 11:51 AM
RSCHAP1's Avatar
Good luck with whatever you decide.
RSCHAP1 is offline
Old 10-17-2022 | 10:24 AM
Its a cool boat, i would definitely do it! if its what you really want $$$ do not matter!
Go roller for sure on the cams, no one does flat tappet anymore!
Hardcore1 is offline
