Trim ram parts for HP transom assembly? >
Old 10-23-2022 | 06:05 AM
Veteran: Army
Default Trim ram parts for HP transom assembly?
It looks like Merc no longer sells parts for the trim rams on newer HP transom assemblies, and only sells the complete ram. The serial number break point is 2A480243 and my transom assemblies are 2A5xxxxx.
I was getting water in the trim fluid on the Stbd side so I was going to use the full Merc overhaul kit but the end cap has been revised, and now the scraper and continuity clip are integral to the cap, and does not appear serviceable. Anyone have experience with this issue or know if I can utilize the older cap on the newer assembly? I can't see paying $650 for a new ram.
DrFeelgood is offline
Old 10-23-2022 | 04:20 PM
Veteran: Army
It appears that the cap may be available though the Merc parts catalog doesn't show it.
8M0118340
seems to be the part number. There is a chain of superceded numbers leading up to that one.
Will update thread when I have more info so that others down the road might benefit.
Old 09-20-2023 | 02:28 PM
8M0118340
seems to be the part number. There is a chain of superseded numbers leading up to that one.
Have you figured anything out on this subject? I have water in my trim pump, I can't see any leaks anywhere except for the pump overflowed into my bilge a bit. (I have the older style pump reservoir). I'm assuming that I have a leak in a ram that is sucking in water. I thought I could order the cheaper of the two rebuild kit options that didn't have hard parts and just replace seals, wipers, etc but I've been told that the end caps are the likely culprit and they are not serviceable; I can't get the internals and replace them. Does this sound correct, I have to buy the whole endcap?
tbev is offline
Old 09-20-2023 | 02:45 PM
Mbam's Avatar
Offshoreonly Advertiser
Looks like that is the correct part
https://www.mercruiserparts.com/merc...40-end-cap-kit
Mbam is offline
Old 09-21-2023 | 03:55 PM
What a bummer,
Do you think I should replace the seals inside that are included with the $30ish seal kit as well? I have water in my pump but no other issues really I'm assuming a ram is letting \ sucking water in.
Thanks Marc!
tbev is offline
Old 09-21-2023 | 04:52 PM
Mbam's Avatar
Originally Posted by tbev
What a bummer,
Thanks Marc!
Probably not a terrible idea once you have it apart but the end cap should solve the water problem.
Mbam is offline
Old 09-21-2023 | 06:01 PM
if you dont replace the rest of the seals I can tell you what part will fail in the next month or so. fix it now while it is apart
compedgemarine is offline
Old 09-22-2023 | 03:44 PM
That's how I typically operate but a dealer told me he just does the cap and not to worry about the internals, that's why I was asking. Thanks guys.
tbev is offline
