Clearcoat
Old 10-24-2022 | 06:19 AM
Default Clearcoat
Does anyone know what clearcoat fountain used on the sides for there fades and graphics. It stands up under the water line
BOATMAN302 is offline
Old 10-24-2022 | 07:21 AM
I replyed on the other thread but from 1996 up its was PPG Concept DCU 2002 or DCU2021. Before that it was Emron.
Wildman_grafix is offline
Old 10-24-2022 | 07:49 AM
Great thanks i heard the ppg was most resistant to below the water line
Old 10-24-2022 | 08:07 AM
Boatman,
There are a lot of model boaters who use the PPG 2021. It is extremely hard and chemically resistant. It holds up well against our methanol/nitromethane/oil mix, as well as gas/oil mix. We always let it fully cure for a week before mounting any hardware to our boats. While it is dry and set after about 18hrs, it is still soft for several days.
Thanks. Brad.
(937)545-8991
Brad Christy is offline
Old 10-24-2022 | 11:28 AM
Boatman,
Thanks. Brad.
(937)545-8991
I did not know that, when I used to paint the RC stuff I always used HOK because I thought they had the only Nitro proof clear. Good info, now the price of PPG is nuts. Just picked up a quart of hardener for some prime and fill, $182!
Old 10-24-2022 | 12:00 PM
have you ever used Standox. Our supplier gave us a gallon of standox 2k hs clear, and says it holds up but not recommended under the waterline.
Old 10-24-2022 | 12:18 PM
I have not.
Old 10-24-2022 | 12:31 PM
Wildman,
Yup. The first boat I cleared with the 2021, we also did a scrap piece of plywood, sealed as if it were a boat. After the week's cure time, we poured straight nitro in it and let it sit until it evaporated. Not a mark. We also did it with straight methanol. Same deal.
From my model boating experience with it, I can't imagine it wouldn't hold up under the waterline in this application.
Yes. It is quite spendy.
I always used HoK colors. They were the only ones that had the chartreuse I liked.
Thanks. Brad.
(937)545-8991
