Go Back  Offshoreonly.com > Owners Forum > Saber
Projects >
Projects
Projects
Old 12-20-2022 | 12:43 AM
Default Projects
Anyone doing any new projects. I am doing a new blower thing. Will post pics as we get into it.
RBeyer is offline
Old 12-22-2022 | 01:56 PM
Just trying to get mine together by the season, but did buy a newer style swim platform similar to the ones they use on newer cigarettes. Was able to get a used pair of 502 Mag takeouts.
What new blower thing did you do? Did you ever get it to run like you wanted to? I recall you were playing with props and had added -2 shorty lower units, but were still trying to dial in that setup.
TexomaPowerboater is offline
Old 12-23-2022 | 07:49 AM
Active Streak: 30 Days
Just curious, were the Mag 502's carbed? What did you spend? Ballpark. I will have a couple this coming Spring and want to price them to a friend who is chomping at the bit. They will need some head work plus plus plus.
Helmwurst is offline
Old 12-23-2022 | 10:06 PM
Magnum EFI. Paid $13K for the pair full bobtail (stock exhaust manifolds) after leak down failed so was implied they needed some head work. I probably would of paid a little more tho cause they were late model gen VI with serpentine belts and really low hours, like 300, freshwater, really clean, ran fine, etc,
Old 01-14-2023 | 09:00 PM
SABER28's Avatar
redid my dash, sent the gauges back to livorsi for new needles (faded) and lenses. took some flattened clear and resprayed the dash itself.
replaced my plastic "box" that mounts my trim and drive switches with an aluminum one painted semi flat black.
sent off all my laminated plastic plates with the engraved letters to be replaced with new ones, the black was getting faded and the letters were yellowing.
i'll post before and after pics when done, heres the dash for now
SABER28 is offline
Old 01-14-2023 | 11:48 PM
Craney's Avatar
I like that layout it makes a sense.
Craney is offline
Old 01-15-2023 | 07:10 AM
Rebuilding a slingshot 388 this weekend was rebuilding the littlefield superchargers they are Big 16-71s replaced all the bearings and seals was disappointed littlefield send snout bearings made in china did not realize it till we pressed one together and it did not feel buttery smooth pressed it apart and ill tell you that circlip down deep on the inside on the drive shaft is a ***** to get out! ordered skf bearings installed and its perfect you can hardly see the china on the bearings so beware gents
boostbros is offline
Old 01-23-2023 | 12:57 AM
We got close wound up -1" had BBlades play with my 32s topped out at 97. Doing 8-71s this year.
RBeyer is offline
Old 01-23-2023 | 12:59 AM
Looks awesome
RBeyer is offline
Old 01-23-2023 | 09:49 PM
SABER28's Avatar
Originally Posted by RBeyer
Looks awesome
was going to call you this fall but got super busy and forgot, sorry. what was the difference in running -1 vs -2 ?
SABER28 is offline
