Can you get 500 hp out of a 454/365 mag? >
Old 01-05-2023 | 12:02 AM
Default Can you get 500 hp out of a 454/365 mag?
I remember a LONG time ago there was threads about the internals of a 454/365hp mag and what they would support as far as hop ups. Maybe posted by Tyler Crockett?? IIRC they have some pretty good internals stock as opposed to the 330hp version. Anyway i cant seem to find them. As the title suggests can you get 500 out of a 365 mag? maybe even a little more? I have two of them in my 31 Scarab thx
pullmytrigger is offline
Old 01-05-2023 | 06:52 AM
SB
Quoting myself from years ago:
365HP Merc Mag engines have:
4 bolt blocks
steel crank, 7/16" rod bolts, forged pistons
Plus the following flat tappet cam:
Mag BBC 454/502 Flat Tappet (rect heads)
.004” 296*, 296*
.006” 286*, 286*
.050” 224*, 224*
.200” 130*, 130*
Valve lift with 1.7 .510”, .510”
LSA 115.5
Merc Part#431-9830 / GM#14096209
ICL 114 ATDC
ECL 117 BTDC
For reference sakes, the carbureted 7.4L Merc 400 / 420 / 425 's
came with the following flat tappet cam:
Crane Part#132561 Grind # H-228/312-2S-14 T1.2
Duration at .004” : 298, 306
Duration at .050”: 228, 236
Lift with 1.7 rocker: .530”, .551”
LSA 114LSA
ICL 109 ATDC , ECL 119 BTDC
SB is offline
Old 01-05-2023 | 07:00 AM
resurrected's Avatar
I have a pair of blowers that would get you there, I'd even sell the complete engines.
resurrected is offline
Old 01-05-2023 | 08:53 AM
Active Streak: 30 Days
Cam, Springs, Intake, Carb and Exhaust, Good Tune, Easy.
Helmwurst is offline
Old 01-05-2023 | 01:42 PM
GPM
540 hp from 468 with cleaned up rectangle port chevy heads, 9.75 compression, air gap intake, performance cam, 850 Holley
GPM is offline
Old 01-05-2023 | 07:35 PM
Here's a link for you.
This is just one combination that gets you there.
PQ290Enticer is offline
Old 01-06-2023 | 08:17 AM
How do aluminum heads hold up on a fresh water but non-closed loop cooling system? My Gen 6 502 is at the machine shop now being brought to a 509 and I don't know if I am to ditch the stock iron rect port heads for Aluminum or have them cleaned up. I am looking for 550ish, it is a Mag MPI but a MEFI 1 so I am ditching it for a Holley multi-port TB injection setup.
Joeyboost is offline
Old 01-06-2023 | 08:48 AM
I was going to go alum heads. Looked very positive to me to run at LOTO. By the time I had the blocks bored, new pistons, decking etc, the budget was blown for the alum heads. Heads were cleaned, 3 angle grind on the valves, new springs, seals, seats cut. Makes plenty of HP & TQ for me. Head work 800.00 vs XXXX.XX
Old 01-06-2023 | 08:59 AM
Personally I'm hoping they hold up great!! This upcoming season will by my first on AFR aluminum heads. I don't have closed cooling either but boat only in fresh water. I did have them "Hard Anodized" because AFR suggested it for marine use but I guess that is only necessary if you boat in salt water. I did not know that at the time.
Old 01-06-2023 | 09:33 AM
If you don't mind me asking what the cost for a set of those are? As Helmwurst stated I too am working on a budget and want it up and running for late may/early June including testing which I know is 20 weeks away but I think I will need all 20 and then some with the way parts are now.
The Holley injection and fuel system alone I'm going to exceed 5K before any engine work.
I am also debating just cleaning up the stock iron heads because again its not a race engine just a healthy lake romper!
