That Little Voice
Old 01-11-2023 | 09:44 AM
Default That Little Voice
So you're starting a project that you're not familiar with and you barely get started and "That Little Voice" is screaming in your ear that you are about to make a huge mistake and you promptly tell that little voice to shut the "f" up because you're busy and trying to concentrate! That just happened to me and this time I'm going to listen.
I need some valve guide work done on my heads after finding out some very important info on valve guide clearance along with many other things. Thought I would just disassemble myself and bring the heads in get them fixed up and put everything back together. This is how far I got then put them back together and will bring them back to the machine shop for the upgrades. I'll let you know if the "Little Voice" was right or not.
PQ290Enticer is offline
Old 01-11-2023 | 12:47 PM
Explain a bit more would be helpful
boostbros is offline
Old 01-11-2023 | 12:53 PM
Refer to this thread:
First Dyno Complete
cheech is offline
Old 01-11-2023 | 01:07 PM
I will tell you what I tell everyone "all my projects were so easy in my head"
Old 01-11-2023 | 04:35 PM
I cannot tell you how many times that "little voice" was right about something...
Baja 252 Islander
bajaman is offline
Old 01-11-2023 | 08:15 PM
SB
Voices
Pretty popular with the offshore crowd. Well the ones that where around for the Miami Vice days anyway.
SB is offline
Old 01-11-2023 | 08:24 PM
SB
Originally Posted by SB
Voices
This:
Old 01-12-2023 | 06:26 AM
resurrected's Avatar
Actually the "little voice" in my head has been drowned out by the screaming!
Trust your gut
resurrected is offline
Old 01-12-2023 | 08:19 AM
RSCHAP1's Avatar
Good luck with the guide clearance !!
RSCHAP1 is offline
Old 01-12-2023 | 08:21 AM
Active Streak: 30 Days
Where are you located?
Helmwurst is offline
