502 head bolts torque
Old 01-21-2023 | 06:36 AM
Default 502 head bolts torque
Morning guys...puting heads on my 502 and found on internet torque spec..They sey longer bolts torque at 78 ft-lbs and shorter once 65ft-lbs is this ok since my is 6 psi boost?Thank you
Zole is offline
Old 01-21-2023 | 07:03 AM
SB
What headbolts ? Ie: whose (manufacturer) and what part# ?
SB is offline
Old 01-21-2023 | 07:09 AM
Morning my good SB..Part number i did not know they have.But i took a caliper and messured thicknest it is 0.043 on threads..does this help
Zole is offline
Old 01-21-2023 | 07:22 AM
SB
Nope.
Manufacturer and model determines the torque value.
SB is offline
Old 01-21-2023 | 07:25 AM
SB
Edit in:
I know you’re from another country and this will probably be expensive to get there, but I’m willing to bet most of us would say to get ARP head bolts for a supercharged 502.
Share a pic of your bolts, just in case you may have these.
SB is offline
Old 01-21-2023 | 07:31 AM
Edit in:
Will do SB..Photo comming wery soon not in garage at the moment.And as allways thank you
Zole is offline
Old 01-21-2023 | 08:00 AM
Pictures SB
Zole is offline
Old 01-21-2023 | 09:14 AM
Posted pictures of bolts
Zole is offline
Old 01-21-2023 | 09:59 AM
The bolts look like ARP, did they also have washers?
AllDodge is offline
Old 01-21-2023 | 10:04 AM
Sorry AllDodge what are washers?
Zole is offline
