Best Bottom Wax/Spray coating
Every fall I have to use hull cleaner to get the Chesapeake mustache off my boat. my white boat turns awful tan/brown by the end of the season.
I'm told it's from all the tanin, decaying plant matter in the water.
Are there any waxes/materials I can apply to the boat to abate some of this? It makes it look awful, and I swear I lose a few MPH/MPG by the end of the season. It's a FasTech 292, No bottom paint.
I usually wax the deck, sides, etc each spring, and was thinking I'd add hull to the list, see if it made a difference.
I've used
for a while now. Seems to work well.
I've used
Friend of mine had his hull ceramic coated. Seemed to keep it cleaner when it's in the lake for a couple of weeks. It's trailer kept for the most part so I don't know how well it would hold up in the water all season
I keep mine in freshwater. That said I use "the works" and hydrogen peroxide mixed 1 to 1.. I tried a commercial cleaner boat shops use but found it can cause fading if left on more than a few minutes.
You may slow the boat down waxing the bottom.
I'm down in the lower Chesapeake and deal with this some - I never leave the boat in the water more than a night or two. Once it's back on the trailer, I use "The Works" to clean it off - does a great job and cheap!
How does the peroxide affect the application?
I've used
https://www.amazon.com/Meguiars-M613...s%2C107&sr=8-3
I've used
I have used this for several years for scum. As soon as I pull the boat out of the water I spray it on and wipe it off with a towel
I would rather have a clean boat than the last 1mph. Usually when I buy a boat, I will give the bottom a good buffing and a coat of good paste wax to seal the pores in the gelcoat. After that, the scum comes right off with the lucas spray wax.
Power 1 works pretty well. I've never had to scrub using it. Just spray it on, let it sit for 10 minutes and hose it off.
FOY - Power One #1
FOY - Power One #1
I'm on a boat lift all summer, we wash it, but can only do (reach) so much. Waxing and losing 1-2 MPH won't kill me. The brown crap will however.
I'm fairly sure by the end of the season the top speed drops from the brown stuff too.
How about this? I'll WAX, JUST the ONE side of the hull this spring - Driver (STRB), that's the side you see from the boat lift/dock.
I'll take pics throughout the season, and we will know if it works!
Homemade Hull Cleaner:
I use 2 Cups acid to 1 gallon hot water, with a good amount of dawn in there to help it stick to the hull longer. Rinse after. use at your OWN RISK.
It is a miracle cleaner for this brown crap on the hull.
UGH. Why is this forum breaking links?
https:// www.maximpulse.com / oxalic_acid_diy.html
remove the spaces.
https://www.google.com/search?client...er+oxalic+acid
remove the spaces.
I dont think waxing the bottom holds up after 1 run at 30 miles per hour. Waxing the hull sides, maybe lasts 10 hours of use, especially in salt. Thats my unscientific opinion just observation.
However that Lucas spray wax is the chit! It smells like bubblegum, use it on the interior all the time for years, even on the vinyl, love that stuff.
