Tabs - looking for another one of these >
Old 03-06-2023 | 10:24 AM
Default Tabs - looking for another one of these
Looking for a plastic spacer that goes on a trim tab ram that prevents it from going all the way up. I'm not sure what they are called, but it's on my older Sunsation Dominator.
(I would post pics, but the system says I'm to new
tznnmp is offline
Old 03-06-2023 | 10:34 AM
Veteran: Army
Are they bennett trim tabs? That's what my older Dominator has. The clip came with a new replacement upper hinge/ram end.
It appears to be made of PVC pipe...
https://www.ebay.com/itm/12375490634...Bk9SR_iFsfzWYQ
DrFeelgood is offline
Old 03-06-2023 | 10:48 AM
Should have stated they are 280 K Planes. Similar, but the plastic is much harder than PCV.
tznnmp is offline
Old 03-06-2023 | 12:03 PM
Team Archer's Avatar
When we used to do that we used a piece of Delron and made a spacer and took the ram apart and slid it over the shaft to stop the travel. That way we could make it what ever size we needed to control the travel of the tab. Regards Dan
Team Archer is offline
Old 03-06-2023 | 08:25 PM
That's exactly what this is....this board is awesome! Thanks Dan!
tznnmp is offline
Old 03-07-2023 | 07:39 AM
Sick Stinger's Avatar
Brotherhood #1
Ive had a few machined like a shaft zinc. 4 bolt set up.
Sick Stinger is offline
Old 03-07-2023 | 08:48 AM
Active Streak: 30 Days
That would be easier than taking the ram apart to put a spacer on.
Helmwurst is offline
