Tri Toon Flooring Replacement >
Old 03-08-2023 | 03:02 PM
Default Tri Toon Flooring Replacement
any one have their Tri Toon Flooring replaced at LOTO
tks
Bad to the bone is offline
Old 03-08-2023 | 03:19 PM
Knot 4 Me's Avatar
What brand toon?
That is a huuuuuuge job. Everything has to come off the deck. Everything. I think that is a job best left to the factory.
Of course, I guess new flooring could be installed over old in just the exposed areas. Not sure how well that would turn out.
I've used Castaway Customs to do some Sea Dek work at the lake. They do PBC's stuff. You could talk to Trent about just putting Sea Dek on over the existing floor that is exposed.
Knot 4 Me is offline
Old 03-08-2023 | 03:30 PM
Default flooring
tks
Old 03-08-2023 | 07:37 PM
That would by far be your most "hassle free" option.
Joe
JPEROG is offline
Old 03-09-2023 | 07:47 AM
Active Streak: 30 Days
Unless you have carpet. Have the same issue. Our toon is in need of ripping out the carpet and some solid surface flooring. Most of the couches are fairly easy to remove. The helm console is not. I think I can unbolt it and use a hoist to lift it a few inches to rip out the carpet and lay the new floor, but that is a project for next Winter.
Helmwurst is offline
Old 03-09-2023 | 08:03 AM
Knot 4 Me's Avatar
Doh! I wasn't even thinking carpet which a lot of older toons have. Was thinking newer synthetic floorings that you may be able to cover over without removal. Carpet would definitely have to come out.
Old 03-09-2023 | 08:20 AM
And it is not even my toon! I just end up being the DD all the time.
Old 03-09-2023 | 08:31 AM
Default Flooring
Yes it is carpet which i hate i will call castway tks
