Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Chip repair advice needed >
Old 03-19-2023 | 01:12 PM
Default Chip repair advice needed
Tips on how to fix these chips? Ive got a gallon of the yellow gelcoat, but no hardener. Appreciate any products and methods...
Thinking marinetex on the deep chip, and then just dab gelcoat in the others to build up, sand / buff / polish?
Thanks in advance!
cdaniel525 is offline
Old 03-20-2023 | 07:24 AM
scarabman's Avatar
Your on the right track. Alternate might be, fill all with Marinetex or similar, and get your self a Prevail sprayer (self contained). Thin the gel a bit, spray whole area of repairs, then sand, buff , polish.
I would check how your gel material matches actual boat, before preceding, as that may help you determine best course of action
scarabman is offline
Old 03-20-2023 | 07:52 AM
Wally's Avatar
Were doomed!
I dont see anything worth filling with marinetex...that will only make your job that much harder to get it smooth and matched with such small chips. I would get some 91% isopropyl alcohol and clean all those chips off.....and build up the gel higher than the surrounding area, Then wet-sand with a straight edge (could be as simple as a 2-3" piece if straight wood with the sand paper wrapped around it) and buff it back to a shine.
That's a very simple explanation cause there's more to this like if the gel is waxed or un-waxed.....you would need multiple steps wet sanding with finer and finer grades of paper. 2 or 3 different steps polishing etc.
-Wally
Wally is offline
Old 03-20-2023 | 04:04 PM
Thanks Wally and scarabman ....
Appreciate the replies. Wasn't sure with as deep as the one into the black would need some filler, but I'll give it a whirl with the gelcoat only... Any suggestions on what hardener for the gelcoat? MEKP seems to be the common answer from Google... but I trust responses here over Google, lol
[EDIT] Did some searching here and found an old GlassDave post and he clarified MEKP and a 2% ratio, so guess I'll pick up a small amount and get to it lol
Old 03-21-2023 | 07:10 AM
Wally's Avatar
Were doomed!
Just verify what kind of gel you have (waxed or unwaxed) if it has the wax you are good to go...if not waxed then get some plastic wrap or parchment paper etc to cover the gel while it dries or it will never fully cure and you'll have a sticky mess to deal with
-Wally
Wally is offline
Old 03-21-2023 | 01:52 PM
scarabman's Avatar
MEKP is correct. What you will find, with gel only, is you will likely have to do multiple applications to get the build up/volume. It will shrink as it cures, and wants to run if you put it on to thick. GEL paste, tinted to color might help.
