Parting out 47 Fountain >
Old 03-23-2023 | 11:48 AM
Default Parting out 47 Fountain
Complete running boat. Hull is wet. Triple 502 mags. Will be removed & sold as complete plug & play drop ins. Rear motors have 11 hours on fresh professional rebuilds, all documentation & dyno sheets. Fr motor has 140 hrs on it. Bravo drives, 6 stainless props, transom assemblies, gen set, air conditioning, power shifts, k planes, navigation, lewmar 1000 windlass etc, everything goes. P.M. me with your needs, trailer will be last to go. Can see & hear motors run, then will pull them out. Let me know if you need pics of something in particular. Thank you.
smashm is offline
Old 03-23-2023 | 01:52 PM
too bad - she's a beauty
Swamplizard is offline
Old 03-23-2023 | 02:01 PM
Yes, it really is a shame. Absolutely everything on this boat works. She's worth more in pieces than taking a low ball offer for it complete.
smashm is offline
Old 03-23-2023 | 06:24 PM
Sick Stinger's Avatar
Brotherhood #1
I don’t think those are bravo 3s
Sick Stinger is offline
Old 03-23-2023 | 06:31 PM
They had bravo 3 decals on them before they were refinished & the serial numbers come up as bravo threes.
smashm is offline
Old 03-23-2023 | 06:45 PM
Veteran: Army
Bravo 3 should be a dual prop drive (2 props on each drive). Maybe someone swapped the lowers for Bravo 1 lowers? I think the uppers are the same.
DrFeelgood is offline
Old 03-23-2023 | 06:47 PM
F-2 Speedy's Avatar
Ive never seen a single prop B3, interesting
F-2 Speedy is offline
Old 03-23-2023 | 07:41 PM
I appreciate the input. I'll pull the serial numbers off of them tomorrow to be sure. What's funny is every part I've ever ordered for them like shift forks etc, have always been under a bravo three listing.
smashm is offline
Old 03-23-2023 | 08:51 PM
Absolutely Genius cutting the sheer down on the hull so far that there is a hull to deck seam that sits nearly underwater, I guess style over practically was the Beakers thought process .
tommymonza is offline
Old 03-23-2023 | 08:55 PM
Brotherhood #1
It’s a bravo one. They did a lower swap. Uppers are all the same.
you can check the serial number 16 different ways. Still a bravo one
but to be sure use that serial to order a prop shaft.
