Donzi 38ZR Bench Seat
Old 03-26-2023 | 07:13 PM
Default Donzi 38ZR Bench Seat
Hi there. I have an 06 38ZR with the standard factory rear bench. Both end seats pop out but the Center cushion wont come off, does anyone know how to remove it? I need to get it reupholstered. I don't see any screws holding it down and I can’t get my fingers underneath it at all. Is it glued down? Can anyone shed any light how to remove it? Thanks so much!
Jcoombs is offline
Old 03-26-2023 | 07:40 PM
Should be screws in the seams between the foam and then up from the bottom of the long front piece.
IGetWet is offline
Old 03-26-2023 | 08:21 PM
Thanks! Not saying they are not there but I can’t find any screws in between the foam (unless they are buried in it). The heads might be buried. I might have to dig in there deeper. I’m curious though why you can’t get your fingers under any edges of the entire cushion. Is it glued or just screwed down on the edges?
Jcoombs is offline
Old 03-27-2023 | 06:10 AM
Mine was just screwed down. Some of the screws do get driven through the vinyl and cannot be seen. You should be able to feel them if you have the foam spread apart and drag a screw driver along the seam.
IGetWet is offline
Old 03-27-2023 | 07:37 AM
Ok. I will take a look at it again. I really appreciate it
Jcoombs is offline
