Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Integrated Swim Platform Repair >
Old 03-27-2023 | 11:56 AM
Default Integrated Swim Platform Repair
Hey All,
I've searched and can't seem to find anything on how to replace a soggy swim platform/swim deck. I can't access the underside of it since it's part of the lower hull/transom shell. I'm replacing my transom, but even with the motors out and a clear line of sight, the space isn't large enough to reach through and access with tools.
How does one repair a swim platform core from the top without disturbing the gel coat around the non-skid part? It's a 1992 Powerquest, and color matching isn't easy, unlike a Fountain or Baja.
I was thinking of using the outer edge of the non-skid as the cutting line with a Dremel or jigsaw. If the damage is bad enough, I should be able to get the non-skid skin off in 1 piece and put it back in with minimal beveling. Thoughts?
Last edited by Speed0verdose; 03-27-2023 at 12:08 PM. Reason: added an image for reference
Speed0verdose is offline
Old 03-29-2023 | 02:01 PM
Looking at it, the easiest and fastest is to do the cut you propose from the top. A hugely more difficult maneuver would be to split the cap and turn it over and do it from the bottom.
There are places to get a 'mold' of the nonskid pattern for the gelcoat if you tear it up too bad, or make a mold of your nonskid prior to tearing into it!
CDShack is offline
Old 03-29-2023 | 02:23 PM
Sydwayz's Avatar
Forum Regulator
Or just rip the nonskid off completely, make repair, fill it back in with flat material and gelcoat; and then have a Sea-Deck pad made larger than your cut area; and not worry about paint matching anything. This will be a nice update for the boat too.
Sydwayz is offline
Old 03-29-2023 | 02:43 PM
this is my plan, i have a CNC router I built to make my own marine mat patterns for a future side hustle.
