Extended anti cavitation plate on a SSm II drive >
Old 04-04-2023 | 08:35 PM
phughes69's Avatar
Default Extended anti cavitation plate on a SSm II drive
I bought a boat that has SSM II drives. 2 previous owners ago someone welded extended anti caviatation plates to the drive. What would be the advanrtage of doing this? Only thing I can figure out would be it might be easier to get on plane. What might be the disadvantages of removing the plate and going back to the stock length.
phughes69 is offline
Old 04-05-2023 | 07:51 AM
resurrected's Avatar
I believe you are correct, the only advantage would be to get on a plane easier. If you are running the original 3 blade props and if the drives are pretty high, I would leave it as it is. If you are going to a more modern 4 blade then you may need to remove it to be able to get out of the hole. I had considered adding extended anti cav ventilation plates to my SSM3's prior to getting newer props. Now it hole shots without a problem (well it did last season).
resurrected is offline
Old 04-05-2023 | 10:08 AM
Don`t remove it !!
ICDEDPPL is offline
Old 04-05-2023 | 11:08 AM
If it ain't broke don't fix it.
And yes am going to be that guy.....it's an anti-ventilation plate not a cavitation plate.
techman is offline
Old 04-05-2023 | 04:42 PM
phughes69's Avatar
Talking
There is always a grammer nazi lurking in the shadows.
Old 04-06-2023 | 08:36 AM
grammer nazi
Ok, I am going to be that guy again......it's not a grammar nazi issue, but using the wrong term nazi.... No Boating For You!
techman is offline
