oil pressure issue
i have a mark iv 515" big block chevy
-4' gm crank
-h beam rods
-wiseco aluminum mini dome pistons
-milodon oil pan 31557
-melling 10774 oil pump with milodon pickup roughly a little over 1/4" clearance from pan bottom
-block was line honed this winter and main bearings have .0025 clearance
-johnson +.300 tall hydraulic roller lifters
-comp 11-456-8 camshaft 242-248 @.050 and .566 lift intake and exhaust
-davis unified ignition hei distributor
-10w30 vr1 is oil used
-10 quarts of oil
long story short my engine has 55-60 lbs of oil pressure as long as i stay under 4000 rpm and anything over it drops as low as 25 lbs. engine has been run over 5 minutes in the water and maintains 55-60 lbs but drops at any higher rpms than 3800.
i can ride around all day long at any rpm under 4000ish and oil pressure is great!
IM AT A LOSS AND DO NOT KNOW WHERE TO GO FROM HERE!!! ANY SUGGESTIONS ARE GREATLY APPRECIATED
-4' gm crank
-h beam rods
-10 quarts of oil
it stays 35-50 at idle when warm after making a 5-10 minute run at 3800rpm. at 3800 rpm it stays 55-60 when running. anything over 4000-4100 it will drop quickly and sit at 20-25
i pulled the motor over the winter and went through it because of the same issue and its still happening.
Not sure what you mean by that ? Did reducing the oil level make the problem quit ?
Also 10774 is not an oil pump number. Which pan do you have ? I am thinking maybe you have the pickup a little too close to the bottom ? I like to see more like 3/8 to 1/2
