Late model Mercuiser ECM Reprogramming
My friend has a 34' Searay Sundancer repowered with anemic 2020 vintage Mercury Horizon 350-300HP V-drives. 3800 rpm with tabs down just to stay on plane. Definitely lacking torque in the 3400 RPM range. I talked with Procharger and they can quickly assemble the hardware, although to their knowledge nobody has been able to reprogram the late model (approximately 2012 & beyond) ECMs. Does anyone know of a person or company that has "successfully broke the code" OR, anyone working on an alternate laptop programmable ECM with harness adapter to interface with the existing sensors, injectors, etc? About 4 PSI of conservative boost would make this (as well as many other late models) different boats. NOTE: My understanding is that this could be applicable to not only the V-Drive configuration, but any 2012+ late model Mercruiser sterndrive. Anyone with Mr. Wizard like knowledge interested? Thanks for the consideration.
By the time you spend the $$$ and add a supercharger system (of any brand) and get the PCM555 reprogrammed, you would have been better off to sell the current power and install some take out 502mpi's or 496Mags.
