Spark Plugs…. 540s loading up
Older Chris craft with newer MerCruiser 502s that according to the previous owner are now 540s with a healthy cam. Had AC, Delco, R 44T spark plugs. They were fouling I had to constantly Rev-it to clean it out. Doing some research, seems like a lot of people were happy with the AC Delco platinum rapidfire #1s. Put those in and runs way better, but now it randomly loads up on fuel and dies at idle.
What’s everyone’s favorite plug for this set up?
What do the plugs look like after a run. Are they burning clean? Based on the pic and your post it appears you have the problem idling around.
What carbs are you running? I would be checking carbs to start and make sure they are set up right.
have to agree with those above. you dont have a plug issue, you have a tuning issue. you are going to have to find out what was done. if they are 540 with bigger cams what tuning to the ecm was done? if none then the ecm is confused by the info it is getting
