572 Whipple Quad Rotor Holly HP EFI Tune Advice >
Old 06-01-2023 | 08:51 PM
Default 572 Whipple Quad Rotor Holly HP EFI Tune Advice
Can some one please take a look at my base tune before I start. I'm new to Holly efi so I'm trying not to screw up. My setup is a 27 Daytona 572 BB Alu heads mild cam huge jacketed headers (Runs dry at the bung ) 8.,5-1 comp ratio small cap Hei Msd blu box with 10 deg in timing (yes ecm controls timing ) Running 91 oct gas Whipple Quad rotor Runs below 140 F connected to a SCx upper and a DD lower spins a 34bravo 4b past redline 6500
I would just feel better if some one could eyeball my base global file and make comments
and or changes with reasons. Like I side Im total nube to Holly efi My last tuning was My Mefi 4a using tuner pro and it sucked.
My eng has 10 60 lb/Hr injectors They are Deka 60 at 43psi the mefi setup ran the fuel at 60psi Always ran super fat off idle good on top Dont remember the AFR
Lets see what else ? I just want my cake and to be able to enjoy it more then a few runs
Send me your email and Ill shoot you the file
Thank you
carter
carterpasch is offline
