Throttle bracket? >
Throttle bracket?
Throttle bracket?
Old 06-06-2023 | 11:05 AM
Default Throttle bracket?
Anyone know if these fit dominators. Looks like it will accommodate the 5.375 square but doesn’t say.
getrdunn is offline
Old 06-06-2023 | 11:20 AM
I’m assuming not as I see both square & spread bore
getrdunn is offline
Old 06-06-2023 | 06:36 PM
You are correct. It will NOT fit. The bolt hole pattern on a dominator is just enough off from a square bore that you can't drill a new pattern. Plus they're wider.
Smitty275 is offline
