454 Mag MPI Hop-Ups >
454 Mag MPI Hop-Ups
454 Mag MPI Hop-Ups
Old 11-30-2002 | 04:35 PM
Ric232
Default 454 Mag MPI Hop-Ups
For those of you with experience, what should my next move be on my 1998 Gen VI 454 Mag MPI motor? So far, I've done:
1. Gil wet exhaust
2. Vortech flame arrestor
3. ECU reprogrammed by Arizona Speed & Marine
4. Adj. Fuel Pressure Regulator (set at 48 psi)
So far, my results have been zero at WOT. The engine runs great, but no more power.
Where should I spend the next chunk of my life savings?
The following are not options:
1. Supercharger (maybe later)
2. Dry exhaust
Thanks,
Old 11-30-2002 | 06:36 PM
maverick1
Red face perf
Push your timing up about 3 deg.
Hot boat has done that on every EFI test they have published. You want your WOT timing around 36 deg BTDC - maybe a little more if you run good gas. Also, IF your system is working as it should - if you have too much timing - your ECU should bake your excessive timing back - if you experience any preignition KNOCK.
My 502 seem lame last year, and in the fall I pushed the timing up the 3 deg. and this past season the boat ran better than ever before.
Good luck
MAV
Old 12-01-2002 | 10:53 AM
Ric232
Gotta Have It,
My ECU has already been remapped by ASM, so I'm not sure I'm safe increasing timing. They told me the remap is calibrated to work off of stock timing. I'm not sure I have much comfort in the knock sensor . . . they sure as hell don't work in any of the American cars I've owned.
Mav,
I'm running at 5000 - 5050 with a 1.5 gear and 23P Mirage Plus. My reprogrammed ECU increased the rev limiter, so that is not the problem. I tried running a 25P Mirage Plus but gained no speed and lost too much acceleration.
Anyone have other suggestions?
Old 12-01-2002 | 11:42 AM
Ric232
That's what I figured. A cam swap does not seem to be an effective way to go at this point.
Old 12-01-2002 | 06:04 PM
Mate 229's Avatar
A Procharger will work wonders on a mag engine. Just keep it at a reasonable boost, 5lbs or less. My 502 puts out 620hp with similar mods to yours and a stage 1 Procharger. There were some good deals on them in the classified section.
Mate 229 is offline
Old 04-18-2004 | 06:32 PM
Scarab22 look at this one.
HPJunkie is offline
Old 09-01-2004 | 12:01 PM
pkspx's Avatar
Default Re: 454 Mag MPI Hop-Ups
I have a 454 in my 96 27' Power Quest its heavy modded with the following
Conversion to carburetor
Dart Alumn. Cyl heads
Dart Intake manifold (hi riser)
Holly Carb
JE pistons 9:6:1 Compression
Cranks Cam Hydrolic camshaft
Hydrolic rollers and lifters
new valve covers
blue printed and balanced
Dyno at 514hp hehe
If you want to see pics of the engine, you can check out the pics on my website
[IMG]www.customtints.com/454/done1.JPG[/IMG]
www.customtints.com/454.done2.JPG
pkspx is offline
Old 09-01-2004 | 12:03 PM
pkspx's Avatar
It will not allow me to edit the top message those URLS again are
and
www.customtints.com/454/done2.JPG
hehe
pkspx is offline
Old 09-01-2004 | 07:38 PM
Pat McPherson's Avatar
Modifying a fuely motor has not worked too well for me.
I changed the cam, exhaust, and had some head work done.
AZ Speed re-calibrated 3 times for me and still didn't get it right.
I have been using the stock calibration and have gained about 300rpm and 4mph with the same prop. So what is that? 40-50HP?
If you want real gains N/A, modify and use a carb.
or
Buy a blower...
Good Luck,
Patrick
Pat McPherson is offline
Old 09-01-2004 | 08:58 PM
Vinny P's Avatar
I hate the winter!!
I gave up on my 454 Magnum. I am building a 540 carb motor.
At least I will be able to tune this motor myself.
Vinny P is offline
