Spark plugs what do you guys like best? >
Old 06-19-2023 | 12:21 PM
Default Spark plugs what do you guys like best?
Looking to get the plugs for my fresh 509, it has slightly increased compression to 9.2:1 wondering what plug works best and what heat range would be best? I ran previously an NGK YR5 but I also saw the AC Delco Rapid Fire #1 plugs. Only plug I don't ever run is Champions I hate them.
Joeyboost is offline
Old 06-19-2023 | 12:33 PM
SB
Factory cast iron heads ?
Delco MR43T or CR43ts.
.035”-.040” gap, no more.
SB is offline
Old 06-19-2023 | 02:32 PM
Yes factory cast iron heads. What is the difference between the MR and CR plugs? Googling now lol
spark plugs
Old 06-19-2023 | 02:39 PM
MR is marine, CR is commercial and the TS is extended tip from what I found. Which is my better choice?
spark plugs
Old 06-19-2023 | 03:00 PM
Wally's Avatar
Were doomed!
The MR's are supposed to be stainless so they dont corrode.....if your in salt then do that...i always boated in fresh and changed the plugs yearly and used the standard CR's with out any issues....
-Wally
Wally is offline
Old 06-19-2023 | 09:30 PM
SB
They don’t make MR43TS’s, thus the CR43TS’s.
c = commercial
m= marine = stainless
TS is extended tip vs T which is normal
43 is good heat range for your engine
SB is offline
Old 06-20-2023 | 06:33 AM
i like and run ngk ur5 projected tip in our hard charging 540
boostbros is offline
Old 06-20-2023 | 02:10 PM
I've been running NGK's for many years. Never had an issue with them.
zz28zz is offline
Old 06-23-2023 | 11:11 AM
bencini231's Avatar
NGK plugs are the only ones we use.
bencini231 is offline
