BRAVO 1 constant knocking after losing serpentine belt >
Old 06-25-2023 | 10:05 PM
Default BRAVO 1 constant knocking after losing serpentine belt
2003 Outlaw 33 twin 496ho's BRAVO 1 outdrives
Had an issue happen yesterday, now getting a knocking sound almost sounds like the engine is knocking but I'm 90% sure it's the outdrive (pulling boat home tomorrow). Knocking sound is consistent constant, same in gear or neutral. Revving in neutral the knocking speed increases with engine rpm (only brought it up to like 1100rpm). Seems I made some mistakes that might do damage to an outdrive. Any ideas what could have broke?
Possibilities that caused damage:
1. Shutting engine down while still in gear, engine was at idle speed.
2. limping it back with one engine off, was in neutral.
3. Something broke in the outdrive and cause the belt to jump off?
I was doing about 60mph when something happened, bring the boat to a stop checked gauges, had oil pressure and temps were initially good. Looked at temp as I raised the hatch, maybe 5secs after temp was okay, now the temp gauge was maxed out. Quickly shut the engine off, but forgot to move shifter to neutral first. (Could that have broken something?) Didn't have tools to get the belt back on, so limped back to shore at 8mph on one engine. (Also heard that may have broken something on the outdrive that wasn't running).
baja 33outlaw is offline
Old 06-26-2023 | 05:24 AM
Being the belt came off, take the belt back off, start it and see if the noise
is still present, if so, check the sea pump, belt tensioner, p/s pump,
alternator and recirculating pump.
Nothing going south in the outdrive would have made it shuck the belt.
JaayTeee is offline
Old 06-26-2023 | 06:55 AM
I'll do that today, it may have also slipped off from being too loose. This was it's second run since taking the belt off to remove the sea pump to change the impeller.
Old 06-26-2023 | 06:58 AM
all of the symptoms you describe sound like an engine problem not an outdrive issue.
1. shutting down with bravo in gear will not hurt the outdrive.
2. limping back home on one motor will not hurt either outdrive.
not totally discounting a locked drive could make your belt jump but siezed drives typically take out couplers, transom plates, transom assemblies, etc.
when I think belt jumped I think siezed pulleys, pulleys not aligned, bad bearings, incorrect tension, or something in top/low end resisting rotation
1MOSES1 is offline
Old 06-26-2023 | 07:37 AM
Knot 4 Me's Avatar
Bad head gasket cross firing between cylinders will make that noise. Easiest thing to do is pull the drive and fire it up. You don't have to run it very long to eliminate the drive as the problem.
Knot 4 Me is offline
Old 06-26-2023 | 09:53 AM
I had a shop do head gaskets when I lost coolant that ended up draining out the engine cylinders when I pulled spark plugs. That was about a year ago, only 8hrs put on the engine since replacement. So they should cover it if it has to do with that, hopefully.
Old 06-26-2023 | 10:02 AM
I would think most likely belt came off, engine overheated and torched a piston or a head gasket. Probably has nothing to do with the outdrive.
snapmorgan is offline
Old 06-26-2023 | 10:44 AM
yeah, it seems like it's most likely the engine. We took the oil filter off and checked the dip stick, no metal shavings. Oil pressure was around 35. Doesn't seem to idle rough, not able to feel anything thumping or hanging when feeling the engine. Only thing we were able to notice is the knocking.
Going to have the mechanic that did head gaskets listen to it this afternoon to it to see if he knows what it is.
Old 06-26-2023 | 02:27 PM
when you say doesn’t idle rough…does it idle and not make any noise. Or it starts and runs..but has a knock?
trying to figure out the cause and effect.
1. what threw the belt?
2. Was the belt and overheating that caused the knock? Or was it knocking before?
1MOSES1 is offline
Old 06-26-2023 | 03:55 PM
starts and runs, only noticeable symptom is the knocking noise as it idles. Wasn't knocking before throwing the belt, it's pretty loud, I definitely would've heard the knock at 4k rpm.
