Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Cobalt Condurre Thru-Hull exhaust wood dry-rot. >
Old 06-26-2023 | 01:26 PM
Default Cobalt Condurre Thru-Hull exhaust wood dry-rot.
Cobalt Condurre 300 Thru-Hull exhaust dry-rot.
It seems to extend down about 6-8"...hollow sound.
Everywhere else is solid.
Glassdave will hopefully chime in...lol...
My thought was to clean out the soft dead wood between the transom inner and outer glass.
Use a good penetrating sealer on the then exposed good hard wood. (In the now hollow core area)
Then refill the hollow with a glass fibre resin system.
Something along those lines.
I'm not averse to pulling the inside glass off in that section, but it seems this maybe a solution that does not compromise strength.
Arneson ASD6 twins.
No engine weight on transom.
Thanks,
Art
Tartilla is offline
