Angles on Outside of 280 K Planesn >
Old 07-01-2023 | 05:24 PM
Craney's Avatar
Default Angles on Outside of 280 K Planesn
I see some guys put small angles on the outside edge of their K planes what is the reason for this?
Craney is offline
Old 07-01-2023 | 05:30 PM
F-2 Speedy's Avatar
Dont think Ive seen them on the outer edge just the inner for more clearance for the prop
F-2 Speedy is offline
Old 07-02-2023 | 08:42 AM
Craney's Avatar
These were on the outside edge of the K planes.
Craney is offline
Old 07-02-2023 | 02:02 PM
scarabman's Avatar
When I raced my single Pantera, (dont need the clearance of the angle as already mentioned) I flipped my 280 tabs around and ran the angle side out. It allowed the tab to contact the water sooner and/or at higher speed. Used to drive Jo nuts!
scarabman is offline
Old 07-02-2023 | 05:36 PM
TeamSaris's Avatar
Driver-441
Racer
Helps with turning. Mostly on stepped race boats. Its like an extra strake for grip. Results may vary.
TeamSaris is offline
Old 07-02-2023 | 06:51 PM
Craney's Avatar
Thank you, a buddy of mine just got the boat and it had 1.5”angle screwed to outside edge of the K planes, but it’s not a stepped hull.26 Martini.
Craney is offline
Old 07-02-2023 | 08:49 PM
my 32 sunsation has them, I know joe and Wayne only did it for a short time, not sure what the pros or cons are tho
blownhammer2000 is offline
Old 07-02-2023 | 11:53 PM
This may be a good discussion thread for trim tab elevation from the hull. ( k-plane base height on transom)
I understand that you don't want k-planes to interfere with the hydrodynamic flow when not required. But wouldn't having them just flush with the transom, and angled up 4° (same as the rise of off transom water flow...being 0° trim tab) be optimal? When in use, there is a better angle of flow, beginning at the root of the tab, vs way down the length of tab, it they are raised?
The result being when in neutral (4° up position) the planes would act as lengthening the hull dynamics?
My 280s ara a full inch above the transom base, parallel. I think 380s would be far better for the application. Better water angles...and less of a water brake.
Angles facing in...would add to that issue?
Tartilla is offline
Old 07-03-2023 | 06:05 AM
scarabman's Avatar
I thought we were talking about something different, being angles on the actual plate. Never mind what I said.
Old 07-03-2023 | 01:48 PM
Craney's Avatar
That’s very similar to what he has the picture that blownhammer posted.
Craney is offline
