Prop pitch changes going from B3 to B1 >
Old 07-06-2023 | 06:38 AM
Default Prop pitch changes going from B3 to B1
While the B3 goes for a repair (might be a little time to complete) we have a B1 to install to get out on the water. 24' Spectre Party Cat type of boat. I know the B1 will not get it up on plane as well as the B1 will but it should work if pitched properly. My question is determining the correct prop for the B1.
B3 2.2 ratio with 24Pitch
24 / 2.2 = 10.9
B1 1.5 with a 17P
17 / 1.5 = 11.3
factor in additional slip for the B1 of say %7 more puts you close to 10.9
Am I correct in just reducing this to a math equation to get the prop close or is there more to it? I did find an old thread that references the gears in the upper of a b3 when mated to a B1 lower.
Bravo 3 to Bravo 1 conversion question
See post 15
BadDog is offline
Old 07-06-2023 | 07:21 AM
What power in the boat?
snapmorgan is offline
Old 07-06-2023 | 07:43 AM
Mbam's Avatar
Offshoreonly Advertiser
Are you changing the complete drive or just the lower? If lower only then the 2.2 upper will give you a 1.65 Bravo 1
Yes the math will get you close
In any case you can use this calculator
https://www.go-fast.com/Knowledge-ba...lip-calculator
Mbam is offline
Old 07-06-2023 | 09:55 AM
The power in the boat is correct for the as installed 2.2 B3, 5.0 MPI on a 24' cat/deck boat.
The entire drive will be removed and replaced with a temporary B1 at 1.5 ratio.
Was trying to verify that a 17 pitch on a 1.5 B1 would be similar to a 24P on a 2.2 B3, it looks like a 17P will be about right.
BadDog is offline
