O.T. atten. Audiofn
Old 11-30-2002 | 09:35 PM
liquid asset's Avatar
Default O.T. atten. Audiofn
I bought 2 Rockford Fosgate 12'' hx2 dvc 1,000 watt peak power dual voice coil subs, what amp do you recomened a r.f. bd100 or a r.f. 1000.2 or a r.f. 700s thanks in advance, I'm doing a system in my 25 for my winter project
liquid asset is offline
Old 11-30-2002 | 09:46 PM
Audiofn's Avatar
Charter Member #232
Need more info bro. What is the rest of the system? How many mids and highs, how many other amps, head unit? Speakers? I could just say use the 1000 but then that could be a HUGE waiste. If you get me more info I will try and answer ya later today.
Jon
Put your best foot forward!
Audiofn is offline
Old 12-01-2002 | 10:16 AM
The Clarion Marine X series head unit, a R.F. 700x 4 channel amp and 6 -M.b. quart 61/2'' coaxials
Old 12-01-2002 | 11:26 AM
Audiofn's Avatar
Charter Member #232
I would go with the Power1000bd or the 1500bd. What you will have to do it take each sub and wire them in Parrallel then take the two subs and wire them in Series. Basically that will give you 500 watts out of the 1000 and 750 out of the 1500. I would try and stay with the db stuff as it will be a little more efficient then the other stuff that they have and will not waile on your batteries so bad. As with any Rockford amp. MAKE SURE you run the proper guage wire to it. I think that both those amps will require a min. of 4 ga wire from the battery and back to the batter just for them, that is NO OTHER AMP hooked up on the same wire. Hope that helps.
Jon
Audiofn is offline
Old 12-01-2002 | 11:35 AM
Charter Member #319
Hey Jon
Did you hook up with D man yesterday?
bajabob38 is offline
Old 12-01-2002 | 11:36 AM
Audiofn's Avatar
Charter Member #232
We hung out and had lunch with the crew but they all poodled out except for Tom with his Bat Boat with the MENTAL motor in it.
I will be back soon so no big deal not to get out this time. I just enjoy hanging with the crew
Jon
Audiofn is offline
Old 12-01-2002 | 10:10 PM
Thanks, Jon
FastEddieBoatRacer
07-12-2005 04:20 PM
wwwTOPDJcom
02-01-2004 10:25 PM
candyman35
04-14-2002 12:08 PM
Red Stripe
02-16-2002 07:31 AM
