GM part # for Merc # 4310811658? >
Old 07-07-2023 | 04:26 PM
Default GM part # for Merc # 4310811658?
Anyone know the GM part number for Merury part 431-811658? This is for a roller cam out of a 1993 Mercury (GM) 350 Magnum (5.7L) Tournament ski boat engine ( was in 1993 Sea Ray "Ski-Ray" competitive ski boat.
Are there other cams comp/crane etc that can be a suitable replacement? Stock application - don't have dollars for upgrading valve components
thanks,.
5drgns76092 is offline
Old 07-09-2023 | 04:24 AM
SB
Carbureted ?
Ck to see if the following has a fuel pump lobe. If it does, this maybe a decent choice. Lower cost than most and still usa made.
https://www.summitracing.com/parts/sum-8800
Pro SBC Stage 1 Hyd. Roller Cam, 204/214 Dur., 112 LSA + 1 Adv, .450/.450 1.5 Ratio, .448/.457 1.6 Ratio, Idle-5800 Range, '87-02 Gen 1 Roller Block
SB is offline
