2003 Bravo 3 trim cylinder >
Old 07-11-2023 | 01:14 PM
Default 2003 Bravo 3 trim cylinder
I am looking for the part number for a 2003 bravo 3 trim cylinder. It is for the starboard drive outside trim cylinder. Hopefully don't need serial numbers off the drives as the boat is in the water. I would like to order the cylinder and line to have ready when I have the boat lifted and on the travel lift for replacement.
Thanks in advance.
283Check is offline
Old 07-11-2023 | 01:23 PM
Knot 4 Me's Avatar
Should work for you.
https://www.mercruiserparts.com/bam/...30973/5398/140
Rebuild kit.
https://www.mercruiserparts.com/bam/...30973/5398/150
Knot 4 Me is offline
Old 07-11-2023 | 08:11 PM
I run these:
https://www.sterndrive.cc/product/Fi...-98704A26.html
https://www.sterndrive.cc/product/Fi...-98703A26.html
SabrToothSqrl is offline
Old 07-11-2023 | 09:36 PM
Thanks, I am not sure if I would want to try to rebuild. Noticed on the way to the Bahamas that we lost starboard trim. When we docked in Green Turtle checked fluid and it was empty, topped it off hit the switch, pump ran but nothing. Looked behind the boat and seen the slick. On a island day we dove on it and the up pressure line is completely out of the cylinder and we could not get it to thread back in. So I am thinking it is stripped. If not I think 2 weeks of soaking in saltwater will have probably have taken its toll on it.
I plan to get new cylinder, lines and bushings. Have the boat hoisted (don't think I want to chance it going on trailer with no trim) fix the issue, pressure wash bottom and relaunch.
283Check is offline
