Making some progress on the ol' Flat deck
Went in the water but had steering issues. New powersteering pump coming and rebuilt cylinder just gotta put it all together and get it bled which is a huuuuuuge pain.
Switched from red/blue fittings to Black.
New
New Dart 345 CNC heads
Jesel belt drives
Jesel shaft rockers
New balancers
.904 lifters
3 stage water pumps
additional oil and fuel cooling
Port injection Tunnel ram intakes
coated pistons
Molnar blower rods and cranks
New cams
Flex fuel sensors for E85
New powersteering pump and second idler
etc etc
New
Jesel belt drives
Jesel shaft rockers
New balancers
.904 lifters
3 stage water pumps
coated pistons
New cams
etc etc
Thanx Dan , I appreaciate your advice at the beginning of this . YOu know your stuff !
Ive been fighting with power steering issues.
Can`t get the system bled, I had a bad leak out of a steering cylinder and the new pump I bought wasn`t working .
Ive now spent about 6hrs trying to bleed the system.
Rebuilt the cylinder and new power steering pump arrived today so I guess we will see .
I did take it out but 40 turns from left to right .. I almost hit a dock and then i was going around in a circle , I spent the day trying to fix the steering.
I also have a lean spot in the lower rpms that I need to tune out .
Data log says 2 lbs of boost at 3400rpm getting on plane, Ive always been in vacuum getting on plane cutting a hole thru the water , I felt like these really weren`t breaking loose but not sure .
2lbs at a low rpm I don`t have any of those fuel cells tuned so gotta get that right first
