502 mag mpi no start
I have a 1996 baja 272 with a bone stock 502 mag mpi. It has ran once all season, on Memorial Day. Before the season I did plugs and wires for a general tuneup since I just bought it last year, and ran good last year. Now the one time I had it on the water it was misfiring and would only get up to 1500 rpm’s. Idled it to the dock and checked the wires to see if maybe they weren’t on the right tips on the distributor. Went to start it and got no crank and the cranking battery was arcing on the negative terminal. Went and got some batteries and it would crank forever but did not want to start. Had to get towed in and have been trying to figure this out ever since.
we did find the kill switch to be bad so we bypassed it but still crank no start. Confirmed it has spark and smells like it has fuel and the pump primes when turning the key. Any other ideas? I’m trying to salvage my boating season and I am at a loss with this. Every mechanic is a month or more out and I’m paying for a slip with a non running boat, lol.
Any help is welcome!
I didn’t run it on the hose before I did anything. Last time it had been started before that was when it was winterized. I checked for spark by grounding out a plug and also with a spark light. Could it be weak spark?
cap and rotor looked disgusting. I’m surprised it even ran last season at all. Replaced cap, rotor, and coil. Seems to to pop a lot now like it wants to start but still won’t start. At this point the only thing I can think of is the ignition module? That’s the only thing aside from the distributor that I haven’t replaced.
ignition modules will die and do strange things but if you were trying to start it before I would pull and clean all the plugs and they may be so fouled with fuel that it does not want to fire.
what do I need to do for this? Just pull them and let them dry? Or should I spray them down with anything specific
Did you check the wires are in the correct position on the plugs too? You only mentioned the cap. Your pickup within the distributor may be corroded as well considering how bad you said the cap was.
