No water out of the exhaust >
Old 07-16-2023 | 02:58 PM
Default No water out of the exhaust
Working on a project boat that I don’t have any history on. I got one of the motors running but don’t have any experience with bravo drives. I put muffs on it with 1/4 turn on the faucet. I’m not getting water out of the exhaust after 30 seconds so I shut it down. I then read I need to plug the holes at the front of the drive so I did that and tried in a couple 10 second intervals and still no water coming out. I then filled up the block with water and tried again, still no water out of the exhaust after about 30 seconds so I shut it down again. I’ll try to post the video and picture of the set up as I don’t think it attached on this post.
looking for advice if I have an issue or concern and what anyone would recommend doing next.
Brad
swellcraftman is offline
Old 07-16-2023 | 03:01 PM
This is the set up I am using currently
Old 07-16-2023 | 03:05 PM
Attached video, maybe? Nope doesn’t look like it.
anyways I got a picture to load, this is what the set up looks like.
Last edited by swellcraftman; 07-16-2023 at 03:10 PM. Reason: Trying to attach video
Old 07-16-2023 | 03:10 PM
Turn the hose on FULL tilt. The raw water pump will take it all. No need to block any other ports. If the block is empty it can take a while to fill and surround the exhaust manifolds prior to exiting the exhaust.
If that doesn't work check the intake side of the raw water pump. Check to see if the impeller is good and the passage way through the outdrive fitting is not plugged.
Don't be shy about feeding her water.
Trash is offline
Old 07-16-2023 | 03:13 PM
Hey thanks Trash!
I’ll try it full blast, how long should I let it go before I should be concerned
Old 07-16-2023 | 03:17 PM
F-2 Speedy's Avatar
the hoses might be reversed on the sea pump ?
F-2 Speedy is offline
Old 07-16-2023 | 03:26 PM
Thanks F-2 speedy
I’m not familiar with the sea pump, I’ll look up a diagram and see if I’m hooked up right.
Old 07-16-2023 | 03:33 PM
F-2 Speedy's Avatar
what engines are you working on, if the pulley rotates clock wise pretty sure the hose from the drive goes on top ?
Old 07-16-2023 | 03:51 PM
thanks F-2 speedy
So the top hose on the sea pump goes to the oil cooler on the back of the engine then circles back to the thermostat housing. The lower hose goes to the drive.
Old 07-16-2023 | 03:54 PM
