Engine Choice on a 30 footer >
Old 07-17-2023 | 05:39 PM
Default Engine Choice on a 30 footer
Outboard power choice....so feel free to ignore if this makes you nauseous.
Looking to power a 6K LB 30 footer. Choices are a single 300 V8 Merc or twin Merc V6 200's. BIG price difference between the two about an additional 20K for the twins. The dealer is actually pushing the 300 over the twins. Ocean boating is the destination. Top speed and fuel burns are about the same on this particular hull.
How should I spend my money?
techman is offline
Old 07-17-2023 | 05:50 PM
badmonkey's Avatar
We are in the process of repowering our 30' Superboat with twin Merc 300XS's....good luck with your decision.
badmonkey is offline
Old 07-17-2023 | 05:59 PM
It’s your budget, so decide what you prefer. Since you asked, having multiple engines for offshore is preferred. With few exceptions, you’ll have an engine to limp back on.
Check the transom before upgrading.
Poker Face Xtreme is offline
Old 07-17-2023 | 06:12 PM
Here’s some things to consider
how far out are you going? Yes motors are much more reliable today but I had a buddy just lose a motor last trip on a pair of fairly new zuke less than 1 year old.
is seatow or whomever out there?
what about weight and balance on the boat. What impact on cg will twins have? those can add a lot of weight. My boat is very sensitive to weight changes ‘72 SeaCraft Seafari 25’
single will be less maintenance costs, less install costs, etc
twins may give some maneuvering and redundancy
I put my boat back to factory as a sterndrive but with a kicker as my get home guarantee.
going way offshore like 80 miles plus I’d recommend having a backup system. Although I know many who do it with a single with no issues…but what will you do if it becomes an issue?
nearshore single is fine. But I suspect you’ll appreciate having twins down the line.
Xcomunic8d is offline
Old 07-17-2023 | 06:25 PM
I'm certainly leaning towards twins.......400HP is better than 300HP, right?
BTW....these are new Merc's, so all the bells and whistles. The V8 does have the AMS midsection and sport exhaust, where the V6's don't, but both are DTS.
Keep the arguments coming.
techman is offline
Old 07-17-2023 | 07:10 PM
Twins if Ocean boating why rely on just one
boomer is offline
Old 07-17-2023 | 10:35 PM
I agree with what the previous guys said - twins only for open water boating.
Skater30 is offline
Old 07-18-2023 | 09:48 AM
Even in fresh water where these center consoles are often used as booze cruises I would get the twins if your planning on doing any people hauling.
TexomaPowerboater is offline
Old 07-18-2023 | 12:26 PM
Why isn't a single 400HP an option?
Or twin 300HP?
6K and only 300HP or 400HP with the twins seems scant.
They claim pretty good performance with either?
cheech is offline
Old 07-18-2023 | 12:34 PM
It's an Axopar 28 and the V10 400 is not an option...yet. The hull is rated for a max 400HP. There is an aftermarket "Brabus" version that supports twin 225's.
techman is offline
