New season, New problems 😣 >
Old 07-17-2023 | 09:14 PM
Default New season, New problems 😣
1990 Merc 7.4 magnum bravo
Runs great for about 10-15 minutes then when running at high rpm- wot starts to surge a little and will start intermittently what I can only describe as a “burst of compressed air sound” like the opposite sound of a backfire. Does kinda clear up when you back off a bit and then will idle fine and start running again and then will do it again. HELP PLEASE!!! Do I have a sticky exhaust valve?! I can’t really tell if it’s ignition or fuel problem. Any input is appreciated!
90MirageTrovare is offline
Old 07-17-2023 | 09:24 PM
Opposite of a backfire out the exhaust sound? (Rich fuel condition)
Or backfire out the carb sound? (lean fuel condition)
My first guess would be it backfiring out the carb (lean) because you're not getting proper fuel flow.
Do you have a fuel pressure gauge installed and can watch to see how many PSI you're getting at WOT?
xlint89 is offline
Old 07-18-2023 | 06:48 AM
check filter at carb fuel inlet
j272 is offline
Old 07-20-2023 | 10:28 PM
I don’t have a fuel pressure gauge, how likely is it that the mechanical fuel pump is starting to go?
Old 07-21-2023 | 06:47 AM
I have seen these filters on the carb inlet clogged.often ignored
j272 is offline
Old 07-21-2023 | 07:33 AM
also could be fuel hose from the tank collapsing or anti siphon valve sticking clogged
compedgemarine is offline
Old 07-21-2023 | 08:29 AM
Just a guess also but what about the fuel tank vent hose clogged or pinched. A long shot but easy to check with loosening fuel cap next trip out. I had mud bees build a condo in my water pick up hose I recently found out.
getrdunn is offline
Old 07-25-2023 | 08:15 PM
Default Still not right.
Changed the carb filter(screen), didn’t really do the “opposite of a backfire” thing but definitely after running for a bit at high rpm to wot, it started just running ****ty, definitely seems like starving for fuel. It only starts acting up after running for about 15-20 minutes. Any more advice is much appreciated.
Old 07-25-2023 | 11:31 PM
You need to check the fuel pressure while running the boat.
Griff is offline
