B-W 72c clutch question
pulled apart a 72c that came with the engines as it had metal in the oil. it ate the reverse clutch plate and I noticed it has an extra forward plate and disc which as I understand it has to be machined to fit. what do I measure or look for to know that was done correctly. It also was missing one reverse plate and disc which I assume is why it ate up the reverse plate. they dont remove reverse plates when adding forward plates do they? pretty sure they screwed up putting it together last time as I know who did it and he gets in a hurry with stuff so who knows.
it has 8 .060 forward clutch discs and 7 .068 steels. according to Marc at BAM the driveline version (these) only used two reverse discs with one steel and he can machine it for 3 and 2 which will save the case so the cases are going to him this week.
